I/O Options and Subcase Information
Entry Used in the I/O Options section or in frequency response (direct and modal) subcases to
request acoustic intensity at the fluid grids.
ACINT (format) = option
Argument |
Options |
Description |
format |
<H3D, PCH, blank> |
- H3D
- Results are output in Hyper3D format (.h3d file).
- PCH
- Results are output in Punch format (.pch file).
- Blank (Default)
- Results are output in all active formats for which the
result is available.
option |
<YES, ALL,
NO, NONE,
SID> |
- YES, ALL (Default)
- Intensity is output for all acoustic grids.
- NO,
NONE
- Intensity is not output.
- SID
- If a set ID is given, the acoustic intensity is output
only for the fluid grids listed in that set.
- The expression for acoustic intensity
is related to the nodal pressure (
) and the complex conjugate of the particle
velocity (
), given by:
