ACMFORCE
I/O Options and Subcase Information Entry Used to request ACM force results at ACM elements, that is, elements used in Area Contact Method for spot weld analysis.
ACMFORCE (format, list) = option
Argument Options Description
format <OPTI, blank>
Default = blank
OPTI
Results are output in OptiStruct results format (.acmfrc file file).
blank
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
ACM force results are output for all elements.
NO, NONE
ACM force results are not output.
SID
If a set ID is given, ACM force results are output only for elements listed in that set.
  1. When the ACMFORCE command is not present, ACM force is not output on ACM elements.
  2. ACMFORCE output is available for the following solution sequences:
    Static Analysis
    OPTI
    Direct Transient Response Analysis
    OPTI
    Modal Transient Response Analysis
    OPTI
  3. PARAM, ACMFOSYS can be defined to output the results in either the local coordinate system or in the conventional OptiStruct beam coordinate system.
