GPCHARGE
I/O Options and Subcase Information Entry Used to output grid point charge results in electrostatic analysis or piezoelectric analysis.
GPCHARGE (format) = option
Definition
Argument Options Description
format <H3D, blank>
Default = blank
H3D
Results are output in Hyper3D format (.h3d file).
blank
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
The grid point charge result is output for all the elements in the model.
NO, NONE
The grid point charge result is not output.
SID
If a set ID is given, the grid point charge result is output only for elements listed in that set.
