SENSOUT
I/O Options and Subcase Information Entry The SENSOUT command can be used in the I/O Options section to control the frequency of output of responses and sensitivities for size and shape design variables to a Microsoft Excel spreadsheet.
SENSOUT = frequency
Argument Options Description
frequency <FIRST, LAST, FL, ALL, N>
Default = FL
FIRST
The results and sensitivities are output for the first iteration only.
LAST
The results and sensitivities are output for the final iteration only.
FL, blank
The results and sensitivities are output for both the first and last iterations.
ALL
The results and sensitivities are output for all iterations.
N
The results and sensitivities are output for the first and last iterations and for every Nth iteration. If N = 5, output occurs for iterations 0, 5, 10, 15, 20, and so on, and the final iteration. All equation and combination responses are output.
  1. This command is ignored when OUTPUT command is present.
