OTIME
I/O Options and Subcase Information Entry Used in the I/O Options or Subcase Information sections to request a set of times for output requests for Transient Analysis for all subcases or individual subcases, respectively.
OTIME = option
Argument Options Description
option <ALL, SID>
Default = ALL
ALL, blank
Output is at all times.
SID
If a set ID is given, output is only at times in that set.
  1. When an OTIME command is not present, the output for all times will be computed.
  2. This command is particularly useful for requesting a subset of the output (for example, stresses at only peak times, and so on).
