MODEL
I/O Options and Subcase Information Entry The MODEL command can be used in the I/O Options section to request output of only a subset of the model and related results for H3D and HDF5 and OUTPUT results files as well as for CMS superelements.
MODEL = format, elset, gridset, rigidset, option
Argument Options Description
format <H3D, HDF5, blank>
Default = blank
The format of output file to which the MODEL command is applied.
H3D
MODEL command is applied to Hyper3D format (.h3d file).
HDF5
MODEL command is applied to Hierarchical Data format, Version 5 (.h5 file).
blank
MODEL command is applied to both H3D format and HDF5 format.
elset <SID, PLOTEL, ALL, NONE>
Default (analysis run) = ALL
Default (CMS SE creation) = NONE
SID
ID of an element SET. A set of elements that describe the subset of the model for which results and model information is to be output. All GRID and SPOINT associated with these elements are also output.
PLOTEL
All PLOTELs in the model and their associated GRID are output.
SKIN
The surface skin of the component is generated and represented as PLOTEL(s) output to the *.h3d file. The solid elements used to generate the skin are deleted in the *.h3d file when this option is used.
ALL
All elements in the model and their associated GRID are output.
NONE
No elements.
gridset <SID, ALL, NONE>
Default (AVL/EXCITE generation run) = ALL
SID
SID of a SET. A set of grids to be added to the subset associated with the preceding elset field.
ALL
All grids.
NONE (Default)
No grids are added to the subset described by the preceding elset field.
rigidset <RIGID/ALL, NORIGID/NONE, SID>
Default (analysis run) =RIGID/ALL
Default (CMS SE creation) = NORIGID/NONE
RIGID/ALL
All rigid elements and their associated GRID will be output.
NORIGID/NONE
No rigid elements will be output.
SID
ID of a rigid element SET. A set of rigid elements that describe the subset of the model for which model information is to be output. All GRID and SPOINT associated with these rigid elements will also be output.
option <OUT, blank>
Default = blank
OUT
Grids and elements related to output requests and loads are added to subset. Such grids and elements include:
  1. Grids and elements in sets as options for output requests.
  2. Grids with loads on including MOMENT, FORCE, SPCD and DAREA.
  3. Elements and rigids attached to grids from 1 and 2.
blank
  1. For CMS superelements output in *.h3d format, only the ASET, BSET, or CSET degrees of freedom are output when the MODEL data is not present. When the MODEL data is present, the .h3d file contains the ASET, BSET, or CSET degrees of freedom and what is specified on the MODEL data.
  2. In addition to the results output, the MODEL data controls the portion of the model that is written to the .op2 and .h3d files.
  3. The gridset always contains the ASET, BSET, or CSET grids along with any grids specified on the model data. In addition, all grids associated with the elements in the elset are included in the gridset. The same is true for grids associated with the rigid elements if RIGID is specified.
  4. The newly generated skin made up of PLOTEL(s) is available in the “Sets” section of the Model Browser. It is labelled “Model_skin_Plotel” in HyperView after the *.h3d file is loaded.
