ELECMAT
I/O Options and Subcase Information Entry Used to output conductivity and resistivity results in electrical analysis.
ELECMAT (format) = option
Definition
Argument Options Description
format <H3D, blank>
Default = blank
H3D
Results are output in Hyper3D format (.h3d file).
blank
Results are output in all active formats for which the result is available.
option <YES, ALL, NO, NONE, SID>
Default = ALL
YES, ALL, blank
The conductivity and resistivity result is output for all the elements (except, gap/contact elements) in the model.
NO, NONE
The conductivity and resistivity result is not output.
SID
If a set ID is given, the conductivity and resistivity result is output only for elements listed in that set.
