NLDEBUG, RMNLMAT
Bulk Data Entry This parameter ignores nonlinear materials specified in the model.
Parameter Description
RMNLMAT Setting this parameter ignores nonlinear materials specified in the model. Typically, certain nonlinear materials are completely ignored while other nonlinear materials are linearized.
  • MATS1, MATVE, MATVP, MCIRON, MATFVE, and MATTVE Entries are dependent nonlinear material entries and are completely ignored during the analysis.
  • MATHE, MGASK, MCOHE, and MCOHED materials are internally converted into MAT1 Entries containing a corresponding linearized version of the nonlinear material.
  1. This parameter can only be specified in the global subcase section (above all the subcases).
  2. This parameter does not require a value to be specified.
