NLDEBUG, NLP2NLC
Bulk Data Entry This parameter converts an NLPARM-based setup to an NLCTRL-based setup in a nonlinear model.
Parameter Description
NLP2NLC Setting this parameter converts an NLPARM-based setup to an NLCTRL-based setup in a nonlinear model. When NLPARM (and additionally NLADAPT, if any) entries are defined in nonlinear models, they are converted internally to NLCTRL.
  • For NLPARM, the following options are moved to the NLCTRL-based setup: NINC, DT, MAXITER, MAXLS, LSTOL, TTERM, MAXAUG.
  • For NLADAPT, the following options are moved to the NLCTRL-based setup: NCUTS, DIRECT, NOPCL, NSTSL, EXTRA, DTMIN, DTMAX, STABILIZ.
  1. This parameter can only be specified in the global subcase section (above all the subcases).
  2. This parameter does not require a value to be specified.
  3. This conversion is conducted after ECHO; if the input deck is echoed out with the ECHO command, the original NLPARM (and optional NLADAPT)-based setup is echoed out.
