RENERGY
Subcase Information Entry Used to output Rotor Energy from Rotor Dynamics using Complex Eigenvalue Analysis for all the subcases or individual subcases, respectively.
RENERGY = option
Argument Options Description
option <YES, NO>
YES
Rotor Energy for Rotor Dynamics using Complex Eigenvalue analysis (when rotors are present) is output in a separate .rengy ASCII file.
NO (Default) or blank
Rotor Energy is not output in the .rengy ASCII file.
  1. Contributions from DMIG, GENEL and element-based rotors are included in the rotor energy calculation.
