LOADJG
Subcase Information Entry Used in the Subcase Information section to select a load set to be applied to joints which are defined via the JOINTG Bulk Data Entry.
LOADJG = option
Argument Options Description
option <SID>
No default
SID
Set identification of a LOADJG Bulk Data Entry
  1. Only one LOADJG entry can be present for each subcase.
  2. LOADJG is currently supported only for Axial, Inline, and Revolute joints.
