Subcase Information Entry The
TSTRU command can be used to assign a temperature set identification
number to the resulting nodal temperatures of a steady-state heat transfer analysis or the
last time step of a transient heat transfer analysis.
Argument |
Options |
Description |
option |
<SID> Default = Subcase ID |
- SID
- This is a temperature set identification number. It may
be referenced from a static analysis subcase, in which
case the resulting nodal temperatures of a steady-state
heat transfer analysis or the last time step of a
transient heat transfer analysis are considered as
applied loads for the static analysis.
- TSTRU is only valid in a
heat transfer subcase.
- If TSTRU does not
explicitly appear in a heat transfer subcase, the Subcase ID is used as the
default.
- A temperature set from a heat transfer
analysis will override any temperature set defined by the Bulk Data Entries
TEMP or TEMPD.
