INVEL
Subcase Information Entry Used to select a multibody initial velocity set to be applied in a multibody problem.
INVEL = option
Argument Options Description
option <SID>
No default
SID
Set identification of INVELB or INVELJ Bulk Data Entries.
  1. Only one INVEL entry can be present for each subcase.
  2. This Subcase Information Entry is only valid when it appears in a multibody subcase.
