SUBCASE
Subcase Information Entry The SUBCASE command can be used to indicate the start of a new subcase definition.
SUBCASE = integer
Argument Description
integer Subcase identification number (SID).
No default (Integer > 0)
  1. Each subcase must be declared with a separate SUBCASE header and a unique SID.
  2. The SUBCASE header is not needed, if there is just one subcase.
