MBSIM
Subcase Information Entry The MBSIM command can be used to select a Multibody simulation definition to be applied in a Multibody problem.
MBSIM = option
Argument Options Description
option <SID>
No default
SID
Set identification of MBSEQ, MBSIM, or MBLIN Bulk Data Entries.
  1. Only one MBSIM entry can be present for each subcase.
  2. This Subcase Information Entry is only valid when it appears in a Multibody subcase.
  3. MBSIM can be used to select only one Bulk Data Entry. MBSEQ, MBSIM, and MBLIN must have unique IDs.
