DESSUB
Subcase Information Entry The DESSUB command can be used in the Subcase Information section, within a subcase definition, to select a constraint set that is subcase dependent.
DESSUB = integer
Argument Options Description
integer <SID>
No default
SID
Set identification of a DCONSTR or DCONADD Bulk Data Entry.
  1. The constrained response referenced by the DESSUB constraint selection must be subcase dependent.
  2. This entry is represented as an optimization constraint in HyperMesh.
