Create a Custom Planar Unit Cell
Define a custom set of edges and points on a 2D plane to use as a planar lattice unit cell.
Custom planar lattice unit cells can be used to fill any implicit volume and can be used with all the same field-driven parameters and properties of built-in unit cells.
On the Implicit Modeling ribbon, select the Planar
Lattice tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
Unit cells can be edited or created using the following workflows. Both options
will open the unit cell editor.
- Edit an existing unit cell:In the guide panel, select the unit cell to edit from the Cell Type dropdown and click Edit
- Create a new unit cell:
In the guide panel, select Create Unit Cell from the Cell Type dropdown.
- Optional:
To import, export, or delete unit cells, use the Import
, Export
, or Delete
button.
- Enter a Name for the cell. All unit cells of the same type require unique names. If you type a name that already exists, a unique number will be appended to the name.
Use the Nodes Table to define the coordinates on the 2D
plane to be used in specifying the lines and points of the unit cell. The
coordinates are normalized between 0-1. The Z component of the nodes are not
used in planar lattices; therefore all coordinates will be projected to the Z
plane before being used in the lattice calculation.
- Add and remove nodes from the table using the Add
or Remove
buttons. - Promote or demote nodes in the list by selecting a row and using the
Up
or Down
buttons.
Use the Connectivity Table to define the edges of the
unit cell by specifying the indices of the start and end nodes for each edge.
The indices are zero-indexed: to reference the first node in the Node
Table, an index of 0 should be used. A node can be connected to
itself to create a point instead of a line.
- Add and remove edges from the table using the Add
or Remove
buttons. - Promote or demote edges in the list by selecting a row and using the
Up
or Down
buttons.
