Create an Implicit Midsurface
Create one or more surfaces or volumes that sit between two implicit bodies. This is useful for creating field-driven effects between two parts/surfaces or to create evenly spaced surfaces between two parts or surfaces.
On the Implicit Modeling ribbon, select the
Midsurface tool.
The Midsurface guide panel is displayed.
- Use the Target collector to select the implicit body that is the origin body of the midsurface.
- Use the Tool collector to select the implicit body that is the terminating body midsurface.
- Select Mode: Single or Multiple to create a midfield based on a single or multiple iso values between the tool and target bodies.
Select Keep: Surface to generate
a thickened isosurface between the target and tool. Select
Volume to set the field on one side of the isosurface
as solid.
Select Fill: Regular to generate
the default solid geometry regions (closest to the target), or select
Inverse to reverse the generated solid and voided
regions.
If Multiple is selected, set the origin and number of
evenly spaced midsurfaces to create.
- Select From: Medial Axis
to place the origin of the midsurface between the target and tool,
creating a symmetrical pattern. Select Target
Surface to set the origin of the midsurface at the
target. The difference between the two modes can only be seen when a
field is applied to the count parameter.
- Enter a value in the Count box to specify the
number of surfaces to place between the target and tool. The count can
be field driven.
If Single is selected, enter a value in the
Iso Value box to set the position of the midsurface.
The Iso Value is a percentage, where 0 is on the target
surface, and 100 is on the tool surface. The iso value can be field
driven.
Enter a value in the Thickness box to set the thickness
offset from the chosen Iso Value. The offset will be
symmetrical from the surface. The thickness value can be field driven.
