Motion
Inspire Motion provides Multibody Simulation (MBS) capabilities to analyze the motion, dynamics, and interactions of interconnected rigid or flexible bodies within a system.
The approach to MBS can vary depending on your perspective and objectives.
- Designer Profile:
Designers typically begin with CAD, leveraging existing geometrical features to define the connections within their mechanisms. The primary objective is to evaluate the performance and functionality of an existing design.
- Analyst Profile:
Analysts often start with a blank slate, employing a hard-point-based design approach. Hard points represent critical locations, such as mounting points or load-bearing connections within and between assemblies. Using these points, mechanisms are constructed with simplified primitive shapes. Joints, located at the hard points, are conceptual in nature. The focus here is on gaining a fundamental understanding of how a new mechanism might function before applying detailed shapes or refinement.
This dual profile approach allows Inspire Motion to cater to both the refinement of existing designs and the conceptual development of new mechanisms, offering flexibility and precision for diverse user needs.
