Mirror Implicit Geometry
Mirror implicit bodies across a symmetry plane.
                On the Implicit Modeling ribbon, select the Mirror
                        tool.
 - The Body button is active. Select an implicit body to mirror.
                Choose between mirroring using a referenced or unreferenced plane.
- Referenced: This tab allows you to use an
                        existing plane or planar geometry feature, which will keep a dynamic link to
                        that object. Click the Select button on the
                            Plane collector and then select a plane to use as
                        the mirror plane.
 - Unreferenced: This tab allows you to define the
                        plane's position and orientation using the on-screen move tool or by
                        selecting the Manual checkbox and specifying explicit
                            values.
                        the mirror plane.
