Combine Implicit Geometry
Combine two implicit bodies into one.
On the Implicit Modeling ribbon, select the
Combine tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Optional: For Visualization Quality, select from Low to Very High quality, which corresponds to a low to very high density of elements. A higher quality produces sharper geometry features but is more computationally intensive. When creating a complicated function, it’s recommended to work using a lower quality and then switch to a higher quality after the function is complete.
- Select two or more implicit bodies.
In the guide panel, select a type of Transition:
- Sharp
- Fillet: If you selected this option, define the fillet Radius. The fillet radius can be entered directly, assigned using a variable or controlled using a field (field-driven design).
- Chamfer: If you selected this option, define the chamfer Distance. The setback of the chamfer can be entered directly, assigned using a variable, or controlled using a field (field-driven design).
- Click OK.
