Inventor Import Options
SimLab supports import of Inventor files upto version Inventor V2025. Various import options in Inventor are explained below.
- Body Name
Body name of the Inventor files can be read into SimLab by enabling the Body Name option.
- Sheet
Sheet bodies can be imported using this option. By default, Solid bodies will be imported into SimLab.
- Color
Color assigned to faces in Inventor model can be imported into SimLab by enabling this option. This color information can be used in color based mesh control.
- Assembly StructureThe assembly structure in the Inventor files can be imported by enabling the Assembly Structure toggle. By default, when importing assembly structure, body names in Inventor file will also be read. Refer the following link to know more about Assembly Structure.
- Facets
Inventor files can be imported directly as faceted geometry
