Import Discrete Models
File > Import > Discrete Models
Introduction
It imports STL, VRML, I-DEAS, Facet Geometry format files and WinProp databases into SimLab without any data loss.
  • STL: This is an industry standard StereoLithography (StL) file format created by Scanning a model. Bio medical data are very common in this form. This contains triangular facet data (*.stl). This is also supported for Quad facet data in ASCII format.
  • VRML: This data format, Virtual Reality Modelling Language, is better than the STL format since it has faces/edges and some topology information to reconstruct solid Brep models. SimLab supports version 1.0 and 2.0 formats (*.wrl). Refer the following link in detail about the VRML Import Options
  • I-DEAS: SimLab can import UGS I-DEAS CAD file known as IDI. This is a graphics tessellation format file created by a special utility in I-DEAS. Please refer to I-DEAS user manual as to how to create IDI files or contact SimLab support.(*.IDI).
  • WinProp Indoor Database: SimLab can import WinProp *.ida files. This file is created by ProMan when exporting a WinProp indoor database to ASCII format.
  • WinProp Outdoor Database: SimLab can import WinProp *.oda files. This file is created by ProMan when exporting a WinProp outdoor database to ASCII format.
