Import CAD
Introduction
CAD files like Parasolid, STEP, CATIA, Creo, JT, NX, SOLIDWORKS, Inventor, ACIS, AutoCAD and ECAD can be imported directly into SimLab without any data loss. Also, CAD files can be translated into Parasolid or STEP.
Parasolid
This option is used to import Parasolid files with extension *.xmt_txt, *.x_t and *.x_b.Refer the following link to know more about the various Parasolid import options.
STEP
STEP files with extensions *.stp and *.step can be imported into SimLab.Refer the following link to know more about the various STEP import options.
CATIA
This option is used to import CATIA files with extensions *.CATPart and *.CATProduct. Refer the following link to know more about the various CATIA import options.Creo
This option is used to import Creo part and assembly files with extensions *.prt and *.asm. Creo import options allow the user to select body type, import coordinates, datum points, design parameters, a simplified representation of an assembly, and assembly structure.
Refer the following link to know more about the various Creo import options.
JT
This option is used to import JT files with extension *.jt written out from various modeling softwares.Refer the following link to know more about the various JT import options.
NX
This option is used to import NX files with extension *.prt. NX import allows the user to specify Units, Body type, Groups and Import Assembly Structure.Refer the following link to know more about the various NX import options.
SOLIDWORKS
This option is used to import SOLIDWORKS files with extension *.SLDPRT and *.SLDASM.Refer the following link to know more about the various SOLIDWORKS import options.
Inventor
This option is used to import Inventor files with extension *.ipt and *.iam.Refer the following link to know more about the various Inventor import options.
ACIS
This option is used to import ACIS files with extension *.sat.Refer the following link to know more about the various ACIS import options.
AutoCAD
This option is used to import AutoCAD files with extension *.DXF and *.DWG.Refer the following link to know more about the various AutoCAD import options.
ECAD
This option is used to import Electronics CAD or ECAD files with extension *.tgz, *.tar, *.zip, *.pcb, *.pcbdoc, *.xml,*.cvg, *.asc, *.hkp, *.pcf, *.dsgf, *.pnf, *.mdfg, *.gds,*.brd,*.mcm, and *Geom.txt.
Refer the following link to know more about the various ECAD import options.
Altium Designer
This option is used to import Altium ECAD files with extension *.pcb and *.pcbdoc.
IPC-2581
This option is used to import IPC-2581 ECAD files with extension *.xml and *.cvg.
Siemens PADS
This option is used to import MentorGraphics PADS ECAD files with extension *.asc.
Siemens Expedition Enterprise
This option is used to import MentorGraphics Expedition ECAD files with extension *.hkp.
Zuken CR-8000/CR-5000
This option is used to import Zuken CR-8000/CR-5000 files with extension *.pcf,*.dsgf,*.pnf and *.mdfg.
Cadence Allegro
This option is used to import Cadence Allegro Expansion ECAD files with extension *.brd,*mcm, and *Geom.txt.
GDSII
This option is used to import GDSII files with extension *.gds.
Refer the following link to know more about the various GDSII_Import_Options
Translate to Parasolid through Spatial
Various CAD format files are converted into Parasolid file using the Spatial Translator and then the converted Parasolid file is imported into SimLab.
- For Translation using Spatial In Linux, motif library (system component) needs to be installed. If using CentOS, then motif library can be installed using the following command: sudo yum install motif For other Linux distribution, use corresponding standard way to install motif shared library.
Translate to Parasolid through CT
Various CAD format files are converted into Parasolid file using the CT translator and then the converted Parasolid file is imported into SimLab.
Translate to STEP
Various CAD format files are converted into STEP file using the CT translator and then the converted STEP file is imported into SimLab.
