Custom Ribbon
This option is used to group frequently used tools in a separate custom ribbon.
Click on the "+" symbol will create a new custom ribbon. User can drag and drop the tools from standard ribbon to this custom ribbon. Tools present in the custom ribbon can also be rearrange.
Following options are available under custom ribbon right click.
Float
This option allows to float the custom ribbon. User can keep the custom toolbar anywhere based on their convenience.
Floating ribbon has three types of views.-
List
Icons
Icons view is used to float all the ribbons in the compact view.
Buttons
Export
This option is used to export the custom ribbon in xml format.Rename
This option allows to rename the active custom ribbon.Delete
This option allows to delete the custom ribbon
Right click on the custom ribbon icon will have the option to rename the tools and delete the tools from custom ribbon.
Right click on the custom ribbon will have customize option. This option allows to export and import the custom ribbon.
