2026
Create, organize, and manage parts and subsystems.
View new features for Altair HyperWorks 2026.
A part is an engineering representation of a physical part, and a part assembly is a group of part assemblies and/or parts.
Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
Parts and part assemblies can be imported into HyperMesh via importing any geometry format or bill of materials (BOM) such as a PDM generated PLMXML file.
Organize part assemblies, parts, and components in your model.
Translate, rotate, reflect, scale, and position selected parts and part assemblies.
The part assembly can be saved as a self-contained binary file, which will include the part assembly based hierarchy and attributes such as components, properties, and materials.
To utilize parts and their functionality to the fullest extent, it’s beneficial being from the CAD to ensure you maintain the digital thread.
Different methods for modeling a part are called representations.
Part representations can be automatically created using BatchMesher, powered by the representation control.
Create your own user defined representations using controls. Representation controls remain available across HyperMesh sessions.
Part representations can be added from external sources such as solver decks and HyperMesh binary files or from the Part Library.
Review library content using the Library Viewer.
Part representations can be loaded from your current HyperMesh session or from the Part Library.
Restore part representations to their original state.
Unload part representations from a session.
Sync PDM metadata (PDM PID, PDM Thickness, PDM Material, and PDM MID) based on a selected part or part's metadata (PID, Thickness, Material, MID).
After importing a BOM and creating respective representations, you can save the representations locally or in the Part Library.
Part representations can be deleted from the current HyperMesh session and from the Part Library.
Settings to configure the representation entity management behavior.
Manage, control and update Major, Study and Library Part revisions using the Part Library.
Group common and unique parts/part assemblies together in part sets, and organize parts and part sets that are unique to a configuration.
Using PDM live connection, on-demand downloading of datasets from external PDM systems such as Teamcenter is possible
Align existing solver files, which lack part hierarchy, with an established part hierarchy.
The complete set-up of Abaqus parts and instances format input files is supported.
The Part Browser can be used to batch the model build workflow.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
Use the Organize tool to move or copy entities into their proper destinations.
Automatically group selected parts into part sets based on comparison method and criteria selected.
Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
Use the Renumber tool to review and organize the IDs of model entities.
Change the order of named entities in database.
Manage the IDs for the entities that you create, and define ID ranges for the entities in each Include file in order to avoid ID duplication across files.
Use the Reps tool to perform representation operations for parts and subsystems.
Scenarios are a mechanism to apply controls to engineering entities.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Compare and update a current HyperMesh session with an incoming model and generate comparison results.
Use the Overlay tool to superimpose a second representation as overlay onto the current (session's) representation and inspect their differences.
Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
Define vectors in 3D space.
Define physical and mathematical characteristics of parts.
Import materials directly from the Altair Material Data Center (AMDC).
Automatically distribute masses on nodes, properties, or parts to match user-defined target mass and center of gravity (COG).
Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
Create, review, and edit RBE2/RBE3 elements and MPC equations.
Use the curve editor to create and plot XY curves.
The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
