Perform Representation Operations
Use the Reps tool to perform representation operations for parts and subsystems.
From the Assembly ribbon, click the
Reps tool.
- From the guide bar, select Parts or Subsystems.
- Make selections in the modeling window.
- Optional:
From the guide bar, click
and select
Show all actions to perform all operations.
From the guide bar, select an operation to
perform.
- Create: create representations using the Change Representation dialog. See Create Representations for more information.
- Load from Session: load representations from current session using the Change Representation dialog. For more information, see Load Representations from Current HyperMesh Session.
- Load from Library: load representations from the Part library using the Change Representation dialog. For more information, see Load Representations from the Part Library.
- Save: save representations locally or in the Part Library using the Save Representation dialog. For more information, see Save Representations.
- Unload: unload representation(s) for selected part(s) or subsystem(s). For more information, see Unload Representations.
Click
