Match Parts
Automatically group selected parts into part sets based on comparison method and criteria selected.
From the Assembly ribbon, click the Match tool.
Click
on the guide bar to set match options.
- Select the necessary parts in the graphics area or through the Advanced selection dialog.
- Optional: Select the Choose reference checkbox and select the parts that will act as a reference for comparison. You can select more than one reference part.
- Select the Link Parts checkbox to have HyperMesh link all the matching parts as Instances of each other if they are not already linked.
Click Match on the guide bar.
A progress bar initializes in the status bar. A part set is created for each group of parts that match each other. The top level part set is created using a combination of comparison method and criteria, and is prefixed with "Grouped_." Nested part sets are created for each part having similar or matching parts, with a prefix of "Matched_."
Note: Link Parts function is available only if the similarity percentage is set to 99.5% or greater.
