2026
View new features for Altair HyperWorks 2026.
Explore the user interface.
View controls enable you to control the view and display of your model in the modeling window.
Quickly find and open the tools and browsers that are available from the ribbons, as well as create entities and solver cards.
Select and deselect entities to modify with other tools. Selected entities are outlined to indicate their selection state.
Use snap points to help align geometry.
Translate, rotate, and align the model.
Several tools require you to define a plane or a vector direction to perform a certain function, such as dragging geometry along a vector, spinning it about an axis, or splitting it with a plane. The Plane and Vector tools are used to define and edit planes and directions.
Use the Measure tool to measure length, angles, radii, areas, volumes, centers of gravity, and bounding boxes.
Learn how to manipulate entities.
Undo and redo actions.
Default keyboard shortcuts and mouse controls.
Supported SpaceBall or SpaceMouse devices.
Create, organize, and manage parts and subsystems.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
