Load Representations from Current HyperMesh Session
- In the Part Browser, right-click on part assemblies or parts and select from the context menu.
In the Change Representation dialog, Load tab, select a
type of representation to load.
Representations that exist in the repository are shown in the Representations column, and their availability is indicated in the Available column.
To send unavailable representations to the BatchMesher directly from the Change
Representation dialog, select the Batch Mesh
Unavailable checkbox.
Note: Available representations will also be loaded when you click OK if the Batch Mesh Unavailable checkbox is selected.
- To save the representations to the Part Library select the Save to Library checkbox.
- Click OK.
In the Confirm Load Representation dialog, specify how
representations are loaded.
- Click Load All to load all available representations into the current session for selected parts.
- Click Skip Loaded to ignore representations that are already loaded for selected parts.
