Sync Metadata To PDM
Sync PDM metadata (PDM PID, PDM Thickness, PDM Material, and PDM MID) based on a selected part or part's metadata (PID, Thickness, Material, MID).
                In the Part Browser, right-click on a part or parts and
                    select  from the context menu.
*When a part has multiple properties, only the first property will display in
                    the PID PDM field when you select Sync Metadata.
                When Material is not mentioned in PDM metadata, material is created by default
                    with MID.
