After importing a BOM that has representations saved in the Part library, you can
load the saved representations.
In the Part Browser, right-click on a part/part assembly
and select Representations > Load > from Library from the context menu.
In the Change Representation dialog, Library tab, select
representations and click OK.
The selected representations are loaded to the Representation folder on the file
system. Similarly, every time a BOM is imported, files are loaded to the
Representations folder, if you retrieve them from the Part Library. Figure 1.
