Workflow Batch
The Part Browser can be used to batch the model build workflow.
Model Build Workflow
The model build workflow includes the following:
- Importing BOM files (PLMXML, UDMXML or CAD BOM)
- Creating multiple representations
- Exporting UDMXML, delta PLMXML files, or Vizmockup PLMXML files (for PDTek use cases)
- Saving the monolithic HyperMesh binary on export
- Saving the representations to the connected part library
- Syncing metadata on export BOM
Create the Batch File
In this task you will create the model build batch file.
Using any text editor, copy the following content into the text editor and name
it, Model_build.bat.
REM Altair HyperMesh v2020 REM Copyright (C)1990-2018 - Altair Engineering, Inc. All Rights Reserved. REM Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication. REM Decompilation or disassembly of this software is strictly prohibited. CLS @ECHO OFF pushd %~dp0 set curr_dir=%~dp0 REM Set below 4 Variables set ALTAIR_LICENSE_PATH=<License_File_Path> set input_plxml="%curr_dir%input_plmxml.xml" set output_plmxml="%curr_dir%output_plmxml.xml" set rep_create={{Crash 5mm} {Crash 10mm}} set Install_Path=C:\Program Files\Altair\2020.0\hwdesktop\hm REM Do not change below this line set Log_File_name=log_%RANDOM%.log set log_file_path="%curr_dir%%Log_File_name%" set batch_exe_path="%Install_Path%\hwdesktop\hm\bin\win64\hmbatch.exe" set batch_tcl_path="%Install_Path%\hwdesktop\hm\scripts\br\views\modules\batch\script.tcl" ECHO . ECHO ################################################## ################################################## ECHO # # ECHO # Altair HyperMesh v2019 # # ECHO # Copyright (C)1990-2018 - Altair Engineering, Inc. All Rights Reserved. # ECHO # Contains trade secrets of Altair Engineering, Inc. Copyright notice does not imply publication. # ECHO # Decompilation or disassembly of this software is strictly prohibited. # ECHO # # ECHO ################################################# ################################################# %batch_exe_path% -tcl %batch_tcl_path% %input_plxml% -blSaveMonolithic 1 - blSaveToLibrary 0 -blSyncMetadataToPDM 0 -createRepresentations %rep_create% - exportFile %output_plmxml% -fileType UDMXML -logFile %log_file_path% -
On the line that reads,
set ALTAIR_LICENSE_PATH=<License_File_Path>, type in the appropriate license path. -
set input_plxml="%curr_dir%input_plmxml.xml", type in the appropriate BOM file (PLMXML file) name and path. -
set output_plmxml="%curr_dir%output_plmxml.xml", type in the appropriate output PLMXML name and path. -
set rep_create={{Crash 5mm} {Crash 10mm}}, specify the representations to create. -
set Install_Path=C:\Program Files\Altair\2019.0\hwdesktop\hm, point to the HyperMesh install path.Note: Only HyperMesh 2019 and later is supported. For version 2020 onward, the directory structure is changed for hmbatch.exe. - Save the batch file.
Run the batch file from the command prompt.
Note: After the batch file is executed, it will start HyperMesh in batch mode and create the representations as specified. You will not see the GUI during this process.
