- Preference File Syntax
Every statement in a script begins with an asterisk, *. Lines without asterisks are treated as comments.
- Shared Preference File Statements
- HyperGraph 2D Preference File Statements
- HyperGraph 3D Preference File Statements
- HyperView Preference File Statements
- HyperStudy Preference File Statements
- MediaView Preference File Statements
- MotionView Preference File Statements
- TextView Preference File Statements
- *Add2DSymbolStyle()
Loads a bitmap file for use as a 2D symbol.
- *Add3DSymbolStyle()
Loads any finite element model that can be displayed in HyperView and uses it as a 3D symbol.
- *AddExportFormat()
Adds the given format to the list of available export formats.
- *AddPaperSize()
Adds the given paper size to the list of available paper sizes.
- *AddPrinter()
Adds a printer to the dialog list.
- *AdvancedReport()
Adds additional parameters when saving a session as a report template.
- *Alignment()
Specifies the position of text in a header or footer region.
- *AnimateManipulation()
Specifies the "Animate during view manipulation" check box in the dialog.
- *AutoDefaultCurves()
Specifies whether to automatically default new curves to be the same as the previous curve loaded from an external file.
- *BackgroundColor()
Specifies the background color for TextView.
- *BeginBrowserContextMenu()
Defines a submenu for the context menu in the Session Browser.
- *BeginCategoryOverride()
Begins a category override block in the preferences file. This is used to post a category-based legend when plotting certain result types.
- *BeginColumn()
Begins a header or footer column block in the preferences file.
- *BeginContextMenu()
Begins a context menu block in the preferences file.
- *BeginDefaults()
Indicates the beginning of the default settings block.
- *BeginDefinitions()
Begins a definitions block in the preferences file.
- *BeginExternalOptimizerDefaults()
Indicates the beginning of the definition of the HyperStudy external optimizer block.
- *BeginFepreDefaults()
Indicates the beginning of the fe-pre default invoke settings.
- *BeginFLD()
Indicates the beginning of an FLD attribute block.
- *BeginFooter()
Indicates the beginning of a page footer block in a preferences file.
- *BeginGraphicDefaults()
Indicates the beginning of the graphics preferences block.
- *BeginHeader()
Indicates the beginning of a page header block in a preferences file.
- *BeginInterpreter()
Indicates the beginning of an interpreter block.
- *BeginLibraryManagement()
Begins a library management block in the preferences file.
- *BeginMdlDefaults()
Indicates the beginning of an MDL preferences block.
- *BeginMenu()
Indicates the beginning of a menu block.
- *BeginModelDefaults()
Indicates the beginning of the model preferences block.
- *BeginModelGUIDefaults()
Indicates the beginning of a model GUI defaults block.
- *BeginPalette()
Begins a palette block in the preferences file.
- *BeginPlot3DDefaults()
Begins the HyperGraph 3D-specific defaults block in the preferences file.
- *BeginPlotDefaults()
Indicates the beginning of the plot preferences block.
- *BeginPlotMacros()
Indicates the beginning of a plot macros block.
- *BeginProfiles()
- *BeginReaderDefaults()
Indicates the beginning of the reader default preferences block.
- *BeginRegion()
Indicates the beginning of a header or footer region.
- *BeginReports()
Begins a reports block in the preferences file.
- *BeginResources()
Indicates the beginning of the general resource block.
- *BeginSolverDefaults()
Indicates the beginning of the definition of the HyperStudy solver block.
- *BeginStatsTemplates()
Begins a statistics templates block in the preferences file.
- *BeginStudyDefaults()
Indicates the beginning of the study preferences block.
- *BeginTemplexFunction()
Indicates the beginning of a Templex function.
- *BeginTemplexFunctions()
Indicates the beginning of a Templex functions block.
- *BeginText()
Indicates the beginning of a text block.
- *BeginTextEditorDefaults()
Indicates the beginning of a text editor preferences block.
- *BeginToolbar()
Specifies the list of toolbar icons to be displayed when HyperView is invoked.
- *BeginUserMode()
Indicates the beginning of a model user mode block.
- *BeginUserUtilityDefaults()
Indicates the beginning of the definition of the HyperStudy utilities block.
- *BeginVideoDefaults()
Indicates the beginning of the video preferences block.
- *BorderWidth()
Defines the region border in a header or footer.
- *BrowserContextMenuItem()
Creates a new, user-defined context menu item in the Session Browser that links selected items to Tcl scripts.
- *CachePalette()
Attempts to accelerate the process which converts AMF files using JPEG frame storage to a faster internal format.
- *Category()
Defines a category to be used for a numeric value.
- *ClosestTimeSync()
By default, displays the closest frame for the current time step for all windows on the current page.
- *ContextMenuItem()
Right-click on an entity to create a new, user-defined context menu item that launches a Tcl procedure.
- *ContextMenuSeparator()
Adds a separator to a context menu.
- *ContourAverageAcrossParts()
Specifies the "Average across part boundary" setting in the the Contour panel when a model is loaded.
- *ContourAveragingMethod()
Specifies the averaging method to be set in the Contour panel when a model is loaded.
- *ContourAverageVariation()
Specifies the averaging variation factor value to be set in the Contour panel when a model is loaded.
- *ContourCornerDataRequested()
Specifies the state of the Use corner data option in the Contour panel when a model is loaded.
- *ContourMultiplier()
Specifies the multiplication factor used to scale the displayed results.
- *ContourResultComponent()
Specifies the result component to be set in the Contour panel when a model is loaded.
- *ContourResultType()
Specifies the result type to be set in the Contour panel when a model is loaded.
- *ContourShowMidsideNodeResults()
Specifies the state of the "Show Midside Node" results in the the Contour panel when a model is loaded.
- *ConverterOutputSettings()
Specifies settings for an external converter.
- *DABEnabled()
Specifies the "display acceleration block" (DAB) setting in the dialog.
- *DefaultFileAccessFromWorkingDirectory()
When the application is launched, this statement specifies the state of default directory location for file browser.
- *DefaultLegendEntityVisibility()
Specifies whether legend entities should be shown or hidden by default.
- *DefaultMaxFrameRate()
Specifies the default setting for the Max Frame Rate slider in the Animation Controls panel.
- *DefaultMouseSettings()
Specifies the default mouse control settings for HyperView
- *DefaultNumPoints()
Specifies the number of points on the Stress Characterization Line (SCL).
- *DefaultPostContourLegendFile()
Sets the default legend for the contour plot.
- *DefaultPostFLDZoneLegendFile()
- *DefaultPostTensorLegendFile()
Sets the default legend for the tensor plot.
- *DefaultPostVectorLegendFile()
Sets the default legend for the vector plot.
- *DefaultResultMathTemplate()
Sets the default template for result math operations.
- *DefaultSignedVonMisesLegend()
Specifies the color scheme that will be applied to a SignedVonMises contour legend.
- *DefineNumericFormat()
Given the value range, specifies the numeric format used for float results in 'Auto' mode.
- *DeformedScaleFactor()
Specifies the scale factor to be applied to the axes, as set in the Deformed panel.
- *Disable3DGraphicsOutput()
Disables 3D graphics output.
- *DisableDirectShow()
Specifies whether or not DirectShow should be disabled.
- *DisableUnitScaling()
Disables the unit scaling feature in HyperGraph 2D.
- *ElementMarkEnabled()
Specifies the check box setting of the Enable element marks option in the dialog.
- *EnableLegendLayoutScaling()
Specifies whether or not layout scaling for the legend is enabled.
- *EnableTemplexCurveNames()
Enables or disables the generation of Templex curve names in the Build Plots panel.
- *EndBrowserContextMenu()
Ends a browser context menu block in the preferences file.
- *EndCategoryOverride()
Ends a category override block in the preferences file.
- *EndColumn()
Ends a header or footer column block in the preferences file.
- *EndContextMenu()
Ends a context menu block in the preferences file.
- *EndDefaults()
Indicates the end of the default settings.
- *EndDefinitions()
Ends a definitions block in the preferences file.
- *EndExternalOptimizerDefaults()
Indicates the end of the definition of the HyperStudy external optimizer block.
- *EndFepreDefaults()
Indicates the end of the fe-pre default invoke settings.
- *EndFLD()
Indicates the end of an FLD attribute block.
- *EndFooter()
Indicates the end of a page footer block in a preferences file.
- *EndGraphicDefaults()
Indicates the end of the graphic defaults block.
- *EndHeader()
Indicates the end of a page header block in a preferences file.
- *EndInterpreter()
Indicates the end of an interpreter block.
- *EndLibraryManagement()
Ends a library management block in the preferences file.
- *EndMdlDefaults()
Indicates the end of an MDL preferences block.
- *EndMenu()
Specifies the end of a menu block.
- *EndModelDefaults()
Indicates the end of a model defaults block.
- *EndModelGUIDefaults()
Indicates the end of a model GUI defaults block.
- *EndPalette()
Ends a palette block in the preferences file.
- *EndPlot3DDefaults()
Ends the HyperGraph 3D-specific defaults block in the preferences file.
- *EndPlotDefaults()
Indicates the end of the plot defaults block.
- *EndPlotMacros()
Indicates the end of a plot macros block.
- *EndProfiles()
Terminates the block started by *BeginProfiles().
- *EndReaderDefaults()
Indicates the end of the reader default preferences block.
- *EndRegion()
Indicates the end of a region block for a header or footer.
- *EndReports()
Ends a reports block in the preferences file.
- *EndResources()
Indicates the end of the general resource block.
- *EndSolverDefaults()
Indicates the end of the definition of the HyperStudy solver block.
- *EndStatsTemplates()
Ends a statistics templates block in the preferences file.
- *EndStudyDefaults()
Indicates the end of the study preferences block.
- *EndTemplexFunction()
Indicates the end of a templex function.
- *EndTemplexFunctions()
Indicates the end of a templex functions block.
- *EndTextEditorDefaults()
Specifies the end of a text editor defaults block.
- *EndUserMode()
Indicates the end of an MDL user mode block.
- *EndUserUtilityDefaults()
Indicates the end of the definition of the HyperStudy utilities block.
- *EndVideoDefaults()
Indicates the end of the video defaults block.
- *EnvelopeCategoryLabel()
Specifies whether to display the filename in the envelope subcase/simulation trace plot category legend.
- *ExternalConverter()
Specifies an external converter to be used.
- *ExternalDecoder()
Specifies an external decoder to be used.
- *ExternalEncoder()
Specifies an external encoder to be used.
- *FLDDisplay()
Specifies the legend type to be set in the FLD panel.
- *FLDFitCurveFLC()
Specifies the check box setting on the Fit curve (FLC) option in the FLD panel.
- *Font()
Specifies the font type, weight, style, and size of text for page headers and footers, and the text editor.
- *Force()
Specifies default display settings for forces.
- *GroupDrawSize()
Specifies the thickness of the entities in a group.
- *GroupDrawStyle()
Specifies the draw style for a group.
- *GroupIDVisibility()
Specifies whether or not the IDs in a group are visible.
- *HeadType()
Specifies how the heads of tensors will be drawn on a Tensor plot.
- *Hide()
Specifies tools to be turned off on the toolbar and pull-down menus.
- *Hst_Precision()
Personal setting in HyperStudy used to manipulate, read, and write numbers.
- *Id()
Indicates the start of a preference file and the release version of the program.
- *Image()
Adds an image to a page header or footer.
- *IncrementBy()
Specifies the setting on the Increment by option in the Animation Controls panel.
- *InterpolationScaleFactor()
Specifies the interpolation scale factor for the axes.
- *InterpolationScaleMode()
Specifies the interpolation scale mode for the axes.
- *IsoShowMidsideNodeResults()
Specifies the state of the "Show Midside Node" results in the the Iso panel when a model is loaded.
- *IsoSyncWithContourPlot()
Specifies the state of the "Sync with contour" option in the legend context menu when a model is loaded.
- *Location()
Specifies the location of the plot legend.
- *Marker()
Specifies the default display settings for markers.
- *MeasureAngleFormat()
Specifies the format of the angle measure values.
- *MeasureFormat()
Specifies the measure format to be set for measures.
- *MeasureOptions()
Specifies the measure options to be set in the Measure panel.
- *MeasurePrecision()
Specifies the measure precision to be set for measures.
- *MeasureType()
Specifies the measure type to be set in the Measure panel.
- *MenuItem()
Creates a user-defined menu item.
- *MessageLogGrouping()
Controls client-specific groupings for posting messages into the Message Log.
- *MinMax()
Saves and restores the current minimum and maximum values of a displayed legend.
- *ModelInfoDefaults()
Sets the default settings for the Model Info (displayed in the top right corner of the of the graphics area).
- *ModelInfoVisibility()
Specifies the setting of the default model note display status on the graphics window when a model is loaded.
- *NoteAnchorToScreen()
Specifies the Anchor to screen setting in the Note panel when a new note is added to the loaded model.
- *NoteAttachment()
Specifies the attachment type to be set in the Note panel.
- *NoteBackGroundColor()
Specifies the note background color setting in the Note panel when a new note is added to the loaded model.
- *NoteBorderThickness()
Specifies the note border thickness setting in the Note panel when a new note is added to the loaded model.
- *NoteDescription()
Specifies the default description text when a new note is added to the loaded model.
- *NoteFont()
Specifies the note font setting (family, weight, slant, and size) for the HyperView notes being drawn in the graphics window.
- *NoteForeGroundColor()
Specifies the note foreground color setting in the Note panel when a new note is added to the loaded model.
- *NoteLineToEntity()
Specifies the style of the hidden part of the line connecting the note to the entity.
- *NoteShape()
Specifies the default note shape when a new note is added to the loaded model.
- *NoteTextAlignment()
Specifies the setting on the Align text option in the Note panel when a new note is added to the loaded model.
- *NoteTransparency()
Specifies the Transparency setting in the Note panel when a new note is added to the loaded model.
- *NumStepsToTrace()
Specifies the default number of latent timesteps displayed behind traced entities.
- *Object()
Specifies primitive attributes.
- *Optimization_Interactive_Execute()
Sets the default to execute a OPT study in interactive or batch mode.
- *Part()
Specifies default part attributes such as part name, color, and visibility.
- *PlotFooterColor()
Defines the default text color for the plot footer.
- *PlotHeaderColor()
Defines the default text color for the plot header.
- *PostScriptIdentifier()
Specifies a postscript identifier.
- *PrintAreaBorders()
Specifies whether window borders are drawn when printing.
- *PrintDisplayedBGColor()
Specifies whether to use white or the displayed background color when printing plots in color.
- *Recompress()
Converts AMF files using JPEG-based frame compression to a faster playing internal video format.
- *RegisterAssemblyWizardFile()
Specifies the file to use as the assembly wizard file when you choose to set the wizard paths to those in the preference file.
- *RegisterCtrlKeyProcedure()
Assigns Tcl procedures to keyboard letter keys.
- *RegisterCustomWizard()
Adds a custom wizard defined in a preference file to a MotionView session.
- *RegisterDefaultSolver()
Sets the default option in the Solvers menu in the MotionView window.
- *RegisterDirectReader()
Registers a model/result reader for use by the Animation client during a session.
- *RegisterExportDLL()
Registers a DLL for use in exporting curves.
- *RegisterExportTemplate()
Adds new curve export formats to the list of existing formats.
- *RegisterExternalColumnReader()
Registers the specified external column reader.
- *RegisterExternalDLLFunction()
Registers a MATLAB function in a library compiled with MATLAB Compiler version 4 or later.
- *RegisterExternalFunction()
Adds external math functions to the program.
- *RegisterExternalOptimizer()
Adds new external optimizer to HyperStudy.
- *RegisterExternalReader()
Specifies an external reader for reading plot data.
- *RegisterFunctionKeyProcedure()
Assigns Tcl procedures to function keys.
- *RegisterHMATHFunction()
Registers a HyperMath HML file in the preferences file. This allows the HyperMath functions in the file to be available in the application, similar to the other internal math functions.
- *RegisterHMATHReader()
Registers a HyperMath reader with the specified characteristics/attributes.
- *RegisterImportTemplate()
Specifies an import template for reading plot data.
- *RegisterMdlStdIncFile()
Specifies the file to use as the standard include file when you choose to set the wizard paths to those in the preference file.
- *RegisterProfile()
Loads profile definitions into HyperStudy.
- *RegisterPythonFunction()
Registers a Python function.
- *RegisterReportsLog()
Registers the log file for the reports that are listed when View Reports is selected from the Analysis menu in the MotionView window.
- *RegisterResultMathPlugin()
Defines a plug-in based operator, which is available through the Expression Builder under the plug-in library.
- *RegisterResultMathTemplate()
Registers a result math template.
- *RegisterSharedReader()
Registers a reader for HyperGraph or HyperView.
- *RegisterSolver()
Registers a solver in the MotionView window.
- *RegisterSolverScript() - HyperStudy
Adds new solver script to HyperStudy.
Adds a new solver invoke script to the Run Solver option in MotionView.
- *RegisterTaskWizardFile()
Specifies the file to use as the task wizard file when you choose to set the wizard paths to those in the preference file.
- *RegisterTemplexFunction()
Adds Templex functions from a file to a session.
- *RegisterUserUtility()
Adds new user utility to HyperStudy.
- *RegisterWizardLibDir()
Specifies which directory will contain the wizard library files when you choose to set the wizard paths to those in the preference file.
- *RemovePreStrain()
Specifies the flag for removing Pre-Strain and creating new datatypes in the HyperView – MultiCore profile.
- *ResetCurveDefaults()
Resets the curve defaults.
- *ResultCacheMemoryConfig()
Modifies memory usage by the Result Data Manager software.
- *ResultMathState()
Enables or disables the result math capabilities.
- *SectionGridLineVisibility()
Specifies whether or not section grid lines should be visible.
- *SectionGridTextVisibility()
Specifies whether or not the section grid text should be visible.
- *Separator()
Creates a separator in a user-defined menu.
- *SetAnimBubbleColor()
Specifies the color of the animation bubble on plots.
- *SetAutoSaveInterval()
Specifies how often the program automatically backs up your current work session.
- *SetAVIFormat()
Specifies the size and color range of images written to AVI files.
- *SetAxisColor()
Specifies the default color for x and y plot axes.
- *SetAxisDefaults()
Specifies default axis settings such as type and number of tics.
- *SetAxisLabelFont()
Specifies the font type, weight, style, and size for the axis of a plot.
- *SetAxisTicFont()
Specifies the font type, weight, style, and size for the axis tic mark labels of a plot.
- *SetBackgroundColor()
Sets the background color specified in the Options panel for plot or graphics windows.
- *SetBarDefaults()
Specifies the default bar color and bar pattern in the Bar Charts module.
- *SetBorderColor()
Specifies the default border color for plot windows.
- *SetBrowserExtension()
Specifies the file browser default extension for graphics, plot, and text editor files.
- *SetBubbleHelpStatus()
Specifies whether bubble help is on or off.
- *SetCurveDataLineLength()
Specifies the length of a line of data points when saved with the Save all curve data to file option.
- *SetCurveDefaults()
Specifies default curve attributes such as line style, symbol style, and color.
- *SetDatumLineColor()
Specifies the datum line color.
- *SetDefaultPageLayout()
Specifies the default window arrangement.
- *SetDefaultPageTitleFont()
Specifies the default font for page titles.
- *SetDefaultPrinterOrientation()
Specifies the default orientation of the printout on the paper.
- *SetDefaultPrintGraphics()
Specifies whether the default print graphics should be polygonal or bitmapped.
- *SetDefaultPrintMargins()
Specifies the width of the left, right, top, and bottom margins.
- *SetDefaultPrintPageSize()
Sets the default paper size to be used when printing.
- *SetDefaultPrintQuality()
Specifies whether the default print quality should be draft, normal, or high.
- *SetDefaultPrintRange()
Specifies the pages to print by default.
- *SetDefaultPrintStyle()
Specifies either black and white or color output.
- *SetDefaultPSFile()
Specifies the default Encapsulated PostScript (EPS) filename for printing to a file.
- *SetDefaultPSPrinter()
Specifies the default PostScript printer.
- *SetFileOn()
Sets a flag that indicates if the filename is displayed, as specified in the Options panel.
- *SetFooterColor()
Specifies the default color of text in plot footers.
- *SetForegroundColor()
Sets the foreground color as specified in the Options panel.
- *SetFrameColor()
Specifies the default frame color for plots.
- *SetFrameOn()
Sets a flag that indicates if the frame number is displayed as specified in the Options panel.
- *SetFunctionUnitExpectation()
Sets the expected units for each unit-dependent parameter of the given function.
- *SetFunctionUnitPolicy()
Defines the units to be used for a specific Templex function.
- *SetGradiantType()
Specifies the gradient type.
- *SetGridlineColor()
Specifies the default color of plot gridlines in a plot window.
- *SetHeaderColor()
Specifies the default color of text in plot headers.
- *SetImplicitGraphicDefault()
Sets the default state of the MDL model's implicit graphics.
- *SetLegendColor()
Defines the default color for the legend border.
- *SetLegendFont()
Specifies the default font for the legend in a plot window.
- *SetLegendPlacement()
Specifies the default legend position in a plot window.
- *SetMemoryWaterMark()
Specifies the upper and lower values for the memory watermark.
- *SetNoteAlignment()
Specifies the default text alignment for notes.
- *SetNoteAttachment()
Specifies the default attachment for notes in plot windows.
- *SetNoteColor()
Specifies the default color of note text for plots.
- *SetNoteFont()
Specifies the font type, weight, style, and size for note text in plots.
- *SetNoteFontSize()
Specifies the font size for notes.
- *SetOrientation()
Specifies the model orientation for graphics windows.
- *SetPartColorList()
Specifies a list of colors to be applied to parts when a model is loaded.
- *SetPrecision()
Sets the number of digits to the right of the decimal that are written to solver deck.
- *SetPreloadMaximum()
Specifies the maximum file size for loading the entire plot file into memory.
- *SetPrimaryFooterFont()
Specifies the font type, weight, style, and size for the first line of the plot footer.
- *SetPrimaryHeaderFont()
Specifies the font type, weight, style, and size for the first line of the plot header.
- *SetPrinterCommand()
Specifies a printer command.
- *SetPrintLegendFontSize()
Specifies the font size for legends while printing.
- *SetPrintLineThickness()
Specifies the default printed line thickness for curves.
- *SetReportAutoFit()
Specifies whether or not autofit is on for reports.
- *SetSecondaryFooterFont()
Specifies the font type, weight, style, and size for the second line of the plot footer.
- *SetSecondaryHeaderFont()
Specifies the font type, weight, style, and size for the second line of the plot header.
- *SetSinglePairCreateDefault()
Indicates whether the default for an entity type being added is single or pair.
- *SetTertiaryFooterFont()
Specifies the font type, weight, style, and size for the third line and all lines thereafter in a plot footer.
- *SetTertiaryHeaderFont()
Specifies the font type, weight, style, and size for the third line and all lines thereafter in a plot header.
- *SetThickLineLimit()
Sets the point at which all curves are drawn with the thin line style.
- *SetTimeOn()
Sets a flag that indicates if the timestep is displayed, as specified in the Options panel.
- *SetToleranceValue()
Sets the value of the time tolerance specified in the Options panel. Checks the Time Tolerance checkbox if the value of the tolerance is nonzero.
- *SetUserMode()
Sets the default user mode.
- *SetWaitBackground()
Specifies an image to be used for the wait background.
- *SetXAxisLabel()
Specifies the default label for the primary x axis.
- *SetYAxisLabel()
Specifies the default label for the primary y axis.
- *SetZAxisLabel()
Specifies the default label for the primary z axis.
- *SetZerolineColor()
Specifies the color of the zero line in plots.
- *ShowAsEvaluated()
Designates whether or not a Templex text file should be shown in its evaluated form when the file is read.
- *ShowMillisecondLegend()
Specifies whether the millisecond legend should be hidden or shown.
- *SGIRGB()
Configures the animation recording and screen capture mechanism to produce SGI-specific bitmap files instead of JPEG files.
- *SmoothViewTransition()
Specifies the "Smooth transition between standard views" check box in the dialog.
- *SpringAsCylinderCoilCount()
Specifies the coil count for a spring, which is to be represented as a cylinder.
- *Stereo3DOptions()
Controls the 3D options used while viewing models in the 3D stereoscopic mode.
- *SyncToActiveWindow()
Specifies whether syncing with the active window is on or off.
- *TensorFont()
Specifies the font properties for the tensor plot text.
- *TensorShowMidsideNodeResults()
Specifies the state of the "Show Midside Node" results in the the Tensor panel when a model is loaded.
- *TensorShowPrefix()
Specifies the state of the Principal Prefix, Normal Prefix, and Shear Prefix check boxes in the Tensor panel.
- *TensorTextColor()
Specifies the color to be used for the tensor plot text.
- *Text()
Specifies the content of page headers and page footers.
- *TextColor()
Specifies the color of text for page headers and footers, and TextView.
- *timestep_precision()
Specifies the number of significant figures to be used in the timestep.
- *TrackingSetAlignWithGlobal()
Specifies the default state of the "Align with Global" option in the Tracking panel.
- *UseLegacyCategoryColor()
Specifies the color scheme that a category-based legend will use.
- *VectorFont()
Specifies the font properties for the vector plot text.
- *VectorShowPrefix()
Specifies the state of the Prefix check boxes in the Vector panel.
- *VectorTextColor()
Specifies the color to be used for the vector plot text.
- *View()
Sets the view of the model to either one of the preset named views or to a specific view given by the 16 values used to set the 4x4 view matrix.
- *WindowIDs()
Indicates the IDS for the windows associated with a report parameter.
- *ZAxisLabel()
Specifies the label for the z axis.
