Restart
Restart command is used to restart the simulation from a previously solved problem. It loads the data of the last time step of the last run of the current problem.
Features
- Right click the flow solution to restart. Restart solution will be displayed only when the solution has some results.
- Restart will create a duplicate solution to perform the operation with the default restart options in the solution parameters.
- The key parameters required for restart will be displayed in the browser for easy visualization.
- User can edit the values by right click the solution parameters of restart
solution.
Note: Restart is supported for the below solutions,- Restart from a steady flow solution
- Restart from a transient flow solution
- Restart from a steady simulation as transient
