Show|Hide Min/Max
Results Model > Right Click > Show|Hide Min/Max
Show Min
This option is used to display the minimum result values and their corresponding node id for each component of the result.
By default, the minimum results value is displayed for the whole model. It is also displayed for selected entities like Body, Face, Edge, Node, and Element.
Show Max
This option is used to display the maximum result values and their corresponding node id for each component of the result.
By default, the maximum results value is displayed for the whole model. It is also displayed for selected entities like Body, Face, Edge, Node, and Element.
Red Circle denotes Minimum and Maximum result values.
Hide Min/Max:
It will hide the node ids with minimum and maximum results values.
