Defining an Antenna Placement Solution
Create an antenna placement solution for the model.
  1. On the Solutions tab, in the Solutions group, click the Antenna Placement icon.
  2. On the Create Solution dialog, specify the following:
    • Name: AntennaPlacement
    • Solver: Feko
    • Solution Type: Antenna Placement
    • Solver class: Frequency-Domain
    • Frequency definition: Single
    • Start frequency: 1.58 GHz
  3. Select the model in the graphics window - this will fill in the bodies in the Select bodies field.
  4. Click OK to close the Create Solution dialog.
