Viewing Results on a 2D Plot
View the 2D far field plot of the antenna.
  1. On the Results tab, in the Results group, click the 2D Plot icon.
  2. On the Feko 2D Plot dialog:
    1. In the Configuration drop-down list, select Antenna_1.
    2. In the Request drop-down list, select FarField_1.
    3. In the Independent drop-down list, select Frequency.
    4. In the Phi drop-down list, select 0°.
    5. In the Theta drop-down list, select 0°.
    6. In the Type drop-down list, select Gain.
    7. In the Component drop-down list, select Total.
  3. To view the y-axis in dB, right-click on the y-axis and, from the right-click context menu, in the Scale drop-down list, select db10.
