Adding an Antenna
Define the GPS antenna using a .ffe file.
  1. On the Analysis group, in the Source group, click the Antenna icon.
  2. On the Antenna dialog, use the default values and specify the following:
    1. Name: Antenna 1
    2. Placement: RectCoordinate_1
    3. Antenna Type:
      • Type: Feko Far Field
      • File name: GPS_Patch_truncated1_FarField.ffe
  3. Click OK to close the dialog.
