Solving the Model
Launch the Feko Solver to calculate the results and view them.
Note: This model takes a while to solve.
On the Analysis tab, in the Options group, click the Solve icon.
After a model is solved, the GS_Antenna_Placement folder contains the .cfx, .fek and .bof files.
Resaving the model after it was solved, the GS_Antenna_Placement_slb folder contains the result and related files for SimLab.
Tip: To share your SimLab model and results, copy the following file and folder:
  • GS_Antenna_Placement.slb (file)
  • GS_Antenna_Placement_slb (folder)
