Specifying the Execute Options
Specify the number of parallel processes to be used when solving the model.
On the Analysis tab, in the
Options group, click the
Solver Settings icon.
On the Format and Execute Options dialog, under
Parallel Execution, select the following check
boxes:
- In the Run the Parallel Feko Solver field, select the True check box.
- In the Specify Number of Processors field, select the check box and type the number.
- Click OK to close the Format and Execute Options dialog.
