After importing a BOM, you can add CAD representations to the Part
Library.
In the Part Browser, right-click on a part/part assembly
and select Representations > Add > to Library from the context menu.
In the Add Representation to Library dialog, select
representations and click OK.
The Add Representation to Library dialog displays information
regarding the availability of representations in library, session, and overwrite
details.
In Figure 1, CAD representations are being added to the Part Library. The
Library column displays 0/8, which indicates there are no CAD representations
available in the Part Library. The Session column displays 6/8, which indicate 6 out
of 8 representations are currently available in the active HyperMesh session. The Overwrite column displays 0/8, which
indicates none of the representations will need to be overwritten.Figure 1.
