User Defined Surface Impedance
This option allows the definition of a complex user defined surface impedance, Zs.
Figure 1. The SK - Add a skin effect (finite conductivity) dialog.
Note: The surface impedance (real and imaginary parts) are defined with the DI card. The SK card then uses the label defined at the DI card.
Parameters:
Material label
Label of the material which will be used as the defined surface impedance (as specified in the DI card).
For example, to model a solid dielectric object with relative permittivity ε r and with conductivity σ at a specific angular frequency ω=2πf , the following surface impedance expression will be used:
Z s = μ 0 ϵ 0 ε r j σ ω
The user defined complex surface impedance Zs relates to the surface current Js and the E-field by E tan = Z s J s where E tan is the tangential E-field and J s is the surface current density.
