A5 Card
This card specifies excitation by an electric Hertzian dipole
On the Source/Load tab, in the Ideal sources
group, click the Electric dipole
(A5) icon.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_a5.png)
Parameters:
- New source
- A new excitation is defined which replaces all previously defined excitations.
- Add to sources
- A new excitation is defined which is added to the previously defined excitations.
- Magnitude of I dl (A m)
- Absolute value of the complex amplitude in Am.
- Phase of I dl (degrees)
- Phase of the complex amplitude in degrees.
- X, Y, Z position
- Coordinates of the position of the dipole in m. These values are optionally scaled by the SF card.
- angle
- Orientation of the dipole in space. The angle (in degrees) is the angle between the dipole and the Z axis.
- angle
- Orientation of the dipole in space. The angle (in degrees) is the angle between the projection of the dipole onto the Z=0 and the X axis.
The power radiated by the dipole in a free space environment is given by
Feko, however, considers the properties of the medium in which the dipole is located, as well as the coupling of the dipole with surrounding structures or other sources (for example other Hertzian dipoles in an array antenna), when calculating the power radiated by the Hertzian dipole.
