BO Card
This card defines a ground plane with the reflection coefficient approximation. All computations that follow this card will include the ground plane (except when it is applied to solution requests where its is only considered in post-processing calculations).
On the Home tab, in the Planes / arrays
group, click the
Plane / ground
icon. From the drop-down list, click the
Reflective ground (BO) icon.
Parameters:
- No reflection coefficient ground
- No ground plane. This option is used to switch off the reflection ground if the effect of different grounds are considered in a single input file, for example to consider a GF card.
- Reflection coefficient ground plane
- Use the reflection coefficient ground plane approximation with the material parameters specified in the remaining input fields.
- Perfectly electric conducting ground
- Use an ideal electric ground in the z-plane. In this case the remaining parameters are ignored.
- Perfectly magnetic conducting ground
- Use an ideal magnetic ground in the z-plane. In this case the remaining parameters are ignored.
- Apply to solution requests
- This option will use the ground plane definition for the request that follow. Supported request types are far fields, near fields, receiving antennas and SAR. The ground plane does not affect the solution but is only considered in post-processing calculations allowing for a fast and efficient way to consider the impact of different infinite ground definitions on a solution.
- Material label
- The label of the medium to be used, as defined in the DI card.
- Z-value
- The ground plane can be defined at an arbitrary z-plane value.
It should be noted that it is not possible to calculate the fields below the ground plane (in the z < 0 half space). In addition all structures must be in the region z > 0. If calculations inside the ground are required, for example when there are structures below ground, the exact Sommerfeld integrals (GF card) must be used.
When using a perfect electric or magnetic reflection coefficient ground plane, structures can be arbitrarily close to the ground (while remaining above it). Segment end points and triangle edges lying in the plane of the ground plane will make electrical contact with a perfect electric ground plane. For a perfect magnetic ground plane the boundary condition forces the current to zero at this point.
If real ground parameters are used, the reflection coefficient approximation is more accurate for structures further from the ground plane. Typically structures should not be closer than about will give a warning if this is the case).
