- Geometric Data
Geometric data consist of mesh data for triangles, segments, connections between triangles and segments, dielectric cuboids as well tetrahedra for the FEM and VEP methods.
- Excitation
Excitation data consist of voltage sources, plane waves, waveguide sources, equivalent sources and Hertzian dipoles.
- Currents and Charges
Currents and charges data are supported for triangles and wire segments and can be requested from CADFEKO or with the OS card.
- Finite Conductivity
Finite conductivity data consists of the material parameters and associated data such as skin effect penetration depth, conductor impedance as well as the power losses per label.
- Near Fields and SAR
Near fields and SAR data consist of values for the electric and magnetic field strength as well as specific absorbtion rate (SAR) data.
- Far Fields and Receiving Antennas
Far fields and receiving antennas data consist of the electric far field data, RCS, gain, directivity and radiated power.
- S-parameters
S-parameters data consist of the S-parameters for all active ports as well as a table of reference impedances used at each port.
- Computation Time and Peak Memory
Computation time and memory data consist of the computation time for the different stages of the solution such as checking the geometry and matrix calculation time. The peak memory and memory per process is also provided.
