Computation Time and Peak Memory
Computation time and memory data consist of the computation time for the different stages of the solution such as checking the geometry and matrix calculation time. The peak memory and memory per process is also provided.
The final section in the output file gives an overview of the computation time, in seconds, in a
tabular
format:
SUMMARY OF REQUIRED TIMES IN SECONDS
CPU-time runtime
Reading and constructing the geometry 0.184 0.184
Checking the geometry 0.095 0.095
Initialisation of the Green's function 0.000 0.000
Calcul. of coupling for PO/Fock 0.000 0.000
Transformation to equivalent sources 0.000 0.000
Ray launching/tracing phase of RL-GO 0.000 0.000
Calcul. of matrix elements 18.036 18.037
Calcul. of right-hand side vector 0.001 0.000
Preconditioning system of linear eqns. 0.437 0.439
Solution of the system of linear eqns. 3.367 3.365
Eigensolution for characteristic modes 0.000 0.000
Determination of surface currents 0.000 0.000
Calcul. of impedances/powers/losses 0.045 0.045
Calcul. of averaged SAR values 0.000 0.000
Calcul. of power receiving antenna 0.000 0.000
Calcul. of cable coupling 0.000 0.000
Calcul. of error estimates 0.000 0.000
Calcul. of electric near field 0.000 0.000
Calcul. of magnetic near field 0.000 0.000
Calcul. of far field 0.000 0.000
other 0.127 0.128
total times: 22.292 22.293
(total times in hours: 0.006 0.006)This table is followed by an output of the peak memory usage (main memory, excluding
possible out- of-core files) which Feko encountered
during any solution
phase:
Specified CPU-times are referring to the master process only Sum of the CPU-times of all processes: 89.173 seconds ( 0.025 hours) On average per process: 22.293 seconds ( 0.006 hours) Peak memory usage during the whole solution: 60.218 MByte (refers to the master process only) Sum of the peak memory of all processes: 233.845 MByte On average per process: 58.461 MByte
