Currents and Charges
Currents and charges data are supported for triangles and wire segments and can be requested from CADFEKO or with the OS card.
Currents on Triangles
The currents and charges data for triangles are provided as
follows:
VALUES OF THE CURRENT DENSITY VECTOR ON TRIANGLES in A/m (no averaging)
Triangle centre JX JY ...
number x/m y/m z/m magn. phase magn. phase ...
1 1.11111E-01 1.11111E-01 0.00000E+00 1.099E-02 147.51 1.099E-02 147.51 ...
2 1.01903E-01 8.28341E-01 0.00000E+00 1.955E-04 62.22 4.668E-03 121.95 ...
3 1.99385E-01 6.49031E-01 0.00000E+00 2.036E-03 131.69 5.377E-03 128.94 ...
4 9.40494E-02 1.16528E+00 0.00000E+00 1.019E-04 29.26 3.685E-03 109.98 ...
5 8.89886E-02 1.49041E+00 0.00000E+00 8.437E-05 -33.65 2.744E-03 100.59 ...
JZ Current magnitude in the
magn. phase 3 corner points
1.099E-02 147.51 1.495E-02 3.067E+00 1.495E-02
4.668E-03 121.95 4.520E-03 4.695E-03 4.842E-03
5.377E-03 128.94 5.591E-03 6.001E-03 5.709E-03
3.685E-03 109.98 3.697E-03 3.718E-03 3.660E-03
2.744E-03 100.59 2.768E-03 2.630E-03 2.850E-03The current density vector
in the complex form is given at the position (X, Y,
Z). The last three columns indicate the value for the surface current density in the
three vertices of the triangles.
Note: The value of the current written in the
.out file will be
affected if averaging of the currents is de-activated in the OS card. If
averaging is requested, the average of the current at the vertices of all three
adjacent triangles is shown.
Charges on Triangles
If the current is requested, the charge on each triangle is also written to the
output file. Only the charge is given as the position of each triangle is the same
as written for the
currents.
VALUES OF THE SURFACE CHARGE DENSITY ON TRIANGLES in As/m^2
Triangle SIGMA
number magn. phase
1 2.03115E-11 165.31
2 8.14289E-12 152.22
3 1.00211E-11 160.36
4 4.59629E-12 119.26
5 4.02388E-12 56.35Currents on Wire Segments
The current on the segments is written as
follows:
VALUES OF THE CURRENT IN THE SEGMENTS in A Segment centre IX IY IZ number x/m y/m z/m magn. phase magn. phase magn. phase 1 0.000E+00 0.000E+00 1.66551E-01 0.00E+00 0.00 0.00E+00 0.00 1.837E-02 -31.39 2 0.000E+00 0.000E+00 4.99654E-01 0.00E+00 0.00 0.00E+00 0.00 1.410E-02 -33.86 3 0.000E+00 0.000E+00 8.32757E-01 0.00E+00 0.00 0.00E+00 0.00 5.366E-03 -35.06
Note: In
the above table the spacing between columns and the number of significant digits
were reduced to facilitate rendering the rows as single lines of
data.
Charges on Wire Segments
If the currents on segments are requested, the charges are also written to the output
file as
follows:
VALUES OF THE LINE CHARGE DENSITY ON SEGMENTS in As/m
Segment Q
number magn. phase
1 1.32488E-11 -90.69
2 4.30863E-11 -120.06
3 6.83730E-11 -125.06Currents and Associated Data for Voltage Sources
For every voltage source the current at the feed point is determined and therefore
the impedance and other related parameters as
follows:
DATA OF THE VOLTAGE SOURCE NO. 1
real part imag. part magnitude phase
Current in A 1.6718E-02 -9.5781E-03 1.9268E-02 -29.81
Admitt. in A/V 1.6718E-02 -9.5781E-03 1.9268E-02 -29.81
Impedance in Ohm 4.5034E+01 2.5800E+01 5.1901E+01 29.81
Inductance in H 5.4750E-08
