Jump to main content
 Altair® SimLab® 2026 Documentation
2026
Index
  1. Home
  2. Analysis
  3. Electromagnetic
  4. 3D Transient Magnetic
  5. Loads
  6. Circuit Designer
  • Welcome
  • Getting Started with SimLab
  • What's New
    See the release notes of the last and previous versions, with the necessary information on new features.
  • Tutorials
  • SimLab Overview
  • Configure
  • User Interface
  • Solution
  • Geometry
  • Sketch
  • Assembly
  • Features
  • FEM
  • Mesh
  • Analysis
    • Material and Property
    • Physics
    • Structural and Thermal
    • Flow
    • Electronics Thermal
    • Flow(SPH)
    • FluxMotor
    • Electromagnetic
      • Introduction of EM Solutions
      • CAD Based Solutions
      • Common EM Geometry and Mesh
      • Common EM Loads
      • Common EM Solution Settings
      • Common EM Solve And Results
      • Specific Motor Tools
      • Coils modeling
      • Conductor described by Surface Impedance
      • Create Mid Wire
      • Export Coil Points
      • Circuit Designer
      • Skewed Motor option
      • 3D Magnetostatic
      • Magnetostatic Integral
      • 2D Magnetostatic
      • 3D Transient Magnetic
        • Introduction of 3D Transient Magnetic
        • Tools
        • Loads
          • Edit Solution
          • Material
          • Coordinate System
          • Symmetry
          • Periodicity
          • Infinite Box
          • Magnet
          • Non-Meshed Coil
          • Passive Conductor
          • Sheet Lamination
          • Motion
          • Thin Region
          • Temperature
          • Magnetic Field
          • Cuts
          • Circuit Designer
          • Imposed Current Coil
        • Solve and Results
      • 2D Transient Magnetic
      • 3D AC Magnetic
      • 2D AC Magnetic
      • 3D Electrostatic
      • 2D Electrostatic
      • Parasitics Extraction
      • AC Supplied Conductors
      • Coupled Solution: Electromagnetic + Flow
    • RF Electromagnetics
    • Molding- SimLab Interface to Altair Manufacturing Solver
    • Welding
    • DOE
  • Results
  • Optimization
  • Electronics
  • Advanced
  • Group
  • Inspect
  • Custom Ribbon
  • Customization using Python
  • Common UI
  • Automation
  • PhysicsAI
  • PhysicsAI Tutorials
  • Custom Default Values
  • Custom Default Mesh Templates
Circuit Designer
Introduction
Circuit Designer is a common tool for several electromagnetic solutions:
Circuit Designer MS MSIM MT MAC ES PE SCAC
2D - - -
3D
Note: The documentation is common for all these EM solutions.
Contents
Circuit Designer: Introduction
Operations of the Circuit Designer Context
Manipulating the circuit components
Different circuit components
On this page
  • Introduction
  • Contents
© 2025 Altair Engineering, Inc. All Rights Reserved.
