Different circuit components
The following are the circuit components supported as of SimLab:
| Component | Icon | Solution | Description | ||||
| MT2D | MAC2D | MT3D | MAC3D | SCAC | |||
| Voltage/Current Source Formula | Source components defined by a parametric formula or value. Orientation defines the flow of current. | ||||||
| Voltage/Current Source Sinusoidal | Sinusoidal source components defined by value inputs. Orientation defines flow of current. | ||||||
| Resistor, Inductor and Capacitor | RLC components. Orientation does not affect the computation. | ||||||
| Coil Conductor and Solid Conductor | FEM coupling components, orientation affects the computation. | ||||||
| N Solid Conductor | FEM coupling components, orientation affects the computation. | ||||||
| Switch Square/Formula | Control components, orientation affects the computation. | ||||||
| Diode |
Semiconductor component, orientation affects the computation. | |||||
| The brush-segment component is a switch describing the electrical contact between a segment of the commutator segment and the brush in a D.C. machine. | |||||||
| Squirrel Cage |
The squirrel cage component is a macro component (or sub-circuit ) that represents the electrical circuit of the machine squirrel cage. |
| Ground | Defines the ground connection. Mandatory for a circuit definition. | ||||||
